sailors hornpipe
- Joined
- Apr 21, 2010
- 53
i bought a 1992 180 nitro fs with 150 hp johnston evinrude- we took it out once ( my boat mechanic buddie and i) just to check for needed maintenence - it had trouble starting and he had to use starting fluid and run it on high neutral for awhile - it took about 4 trys to get it started and once we ran it in the lake for awhile and shut it off - it would restart right away with no hesitation - my bud says i need to drain the old gas out which i estimate to be 10 gallons - i have thought on how i would do this and saw a 10 dollar siphoning pump with tubing at walmart and planned to buy and siphon out old gas - but then i read another thread here that made me think twice- the thread was asking how to clean out an old gas tank - apparently the thread starter has debris in his gas tank and wants to clean it out- the replys he got were to use a shop vac or siphon and to be sure to ground himself to the tank - then someone said (dont use a shop vac! ) as it is electric and could cause a spark- it was also mentioned that a n empty gas tank is full of fumes and very explosive- mind you the temp here in my part of texas is going to be at or above a 100 degrees for the next week at least- so first how do you ground yourself to the tank? second am i going to create a bomb in my driveway by emptying the tank? third what is a fuel sending unit and am i going to damage anything by inserting a siphoning tube into the tank? fourth where do i dispose of the gas? fifth if i do nothing / what is runnig the old gas through the engine going to hurt? i know the boat was sitting at the boat dealer since at least nov of 2009 when it was traded in (supposing the salesman is telling the truth) and dont know when it ran last before that - so we are guessing the gas is at least a year old . what do yall think
