Sitting 3 Or 4 YTears - What To Do?
newjavlenowner
i just got a 1996 javlen bass boat that has been sitting for 3or4 years what should i do or check for to get it ready for spring
GA_Boater
newjavlenowner
Welcome aboard. Moved this from a dead 13 year old thread. Please look at the Help Tip on top of the page.
I'm guessing you are asking about the motor, so I left it in the Mercury/Mariner section.
You probably have some old gas that needs to drained out of the tank, carbs that need rebuilding, water pump impeller that needs to be changed and the lube in the lower unit that needs to be check for water and changed. Most likely a few more things to look at, too.
