Re: size of engine
$100 on EBay, MIE 233 hp 351 complete with fresh water cooling.
Six months ago, cost me more money in fuel for the truck to pick it up in
FLA.
Interesting story on the 351.
Auto shop at the tech college were I work overhauled the engine.
Bore and deck the block, turn the crank, re-size the rods, valve job with new guides on the decked heads, engine balance, assembly, as a class project.
Owner paid for shot peening the rods, new pistons, Crane cam and lifters, oil pump, chain, gasket kit, rings and bearings, $650
Topped it off with an Offenhauser Dual Port manifold $75 and 650 Holley $50 off EBay. Holley rebuild kit from Summit for $28, (carb rebuild, class project). I think it was $30 for the Holley throttle conversion kit from Summit. The Pertronix ignition and plug wires were taken off the 188hp engine the 351 replaced. Center riser exhaust manifolds replaced the log style, $200. New exhaust elbows off EBay $15. Exhaust hose from NAPA $2 per foot. With the closed system cooling the boat owner installed a heat exchanger with fan in the front off the 19 footer, it's warm in the boat in Nov. and Dec. now.
