Size of gas tank for 1996 FM170
Dr Jane
Just bought a 1996 FM170 and I have disconnected the oil pump as it was clogged. I need to know how big the gas tank is as I am now manually mixing the gas/oil for the 2stroke motor. I can't find the owner's manual on-line.
MuskyHunter1
Re: Size of gas tank for 1996 FM170
From the sea nymphs I've had apart, you should be able to remove the center section of floor that covers the aluminium fuel tank, they are stamped with all the tank data including capacity and date of mfg.Hope that's helpful!
