Re: skeeter boat hopping at high speed
I have a sf175 Skeeter bass boat with a Mercury xr4 150. boat runs great up to 3/4 throttle and starts whale hopping real bad. had a 12in jack plate and went with no jackplate and back to a 6in still the same thing. Also tried lowering and raising the motor and no change. the motor has a 24p ballistic XL prop. tried a tempest plus 23p no change. left side fin on lowerunit is boken would this have an affect on this? Any suggestions would be great. Thanks
Are referring to what is commonly called Porpoising? I'd guess the broken fin could certainly cause some porpoising, depending on how damaged it is. Post a pix of the motor on the jack plate you last ran it on, and some pix showing the plate's settings/adjustments (if equipped), the plate to the transom, and the motor to the plate. More knowledgeable iboaters will get you squared away, but they'll need pix for reference...
Here are 2 links to info @ porpoising:
Iboats
Another site
There is lots of info @the iboats forums, take a look around you may find answers to questions you didn't know needed to be asked.
I hope those 2 links help answer your question & the iboats crew will get ya planed out & riding smooth again soon..
Triming the motor up and down a lot make any difference? I've heard some guys saying trim tabs can help with this issue.
I think you meant trimming the motor in & out, adjusting the angle of the motor relative to the plane of the water and the plane of the transom. Tilt, if equipped, would be more likely to be described as adjusted up & down, but is usually only 2 stops/settings: tilted up for trailering & tilted down for running, so not ideal for adjusting the motor to reduce porpoising.
Trim tabs and the additional hydro fin are both 2 ways of reducing porpoising. But if the hull has a hook, the fore & aft weight distribution, the motor's trim angle or motor height on the transom are the problem, you might address those areas 1st. Then if all else fails to correct the porpoising, try the tabs or the fin.
