Skeg guard went bye bye
towdog
In my haste to get the boat in the water I forgot to check if the motor had been trimmed up and the skeg guard cut clean off going over a speed bump the 50 yards between where I store it and where I put it in. Terrible sound and I knew exactly what had happened when I heard it. <br /><br />What are my options? I've heard that you can buy an aftermarket product called a skegguard to bolt over the remaining skeg that's supposed to be even better than the original guard. But my problem is that I don't think I have enough spare to bolt through. I'm afraid my only option is to weld the sucker back on. Please tell me that this will be an OK solution and that I do not have to replace my entire lower unit.<br /><br />Could a prop place fix this or I guess I could go to any old welder? <br /><br />Thanks......
rickdb1boat
Re: Skeg guard went bye bye
Yes, welding would be the best option. A prop shop should be able to take care of it for you...
