I have a ski boat with a 351 inboard (commander) engine with a velvet driect drive transmission. I have an odd problem. When the engine cover is lifted it idles perfectly. As soon as you close the cover over the running engine it starts to drop in rpm off idle and then dies. If you open the cover before it dies it will recover and idle all day long. I changed out the carb for a new one. I then thought it might be a vaccume leak, so i changed the intake gaskets..and its still happening when the cover is closed. I have tried tapping on wiring and can't find anything to cause the idle to drop. I replaced the pcv valve. I even disconnected the throttle cable so the carb was not hooked up to any cables..just the fuel line...and it still started to stumble after the cover was closed. Yes the air cleaner (spark arrester) has been cleaned. I have a big 8" access port in the floor to tighten the ski pylon, and have even tried it with the port cover off, still tries to die when the cover is closed.
Any ideas????
Bill
Ladson SC
Any ideas????
Bill
Ladson SC
