SKI BOAT PROP - HELP
MESS147415
hello guys - ive just got my ski boat on the water for the first time after a winter restoration project. engine is an inboard marinised 3.5 litre V8 rated at 150bhp direct drive thro hull bottom to 3 blade bronze prop which measures about 13 inch dia. boat is very quick to plane and will do about 35mph at 5000rpm (not full throttle).<br />Two questions, sometimes when accelerating, particularly when or just after turning, there is a hevy rumbling from the prop area which goes if i ease back the revs - is this cavitation and what can i do about it?<br />secondly, is my prop too small? as a guideline what size prop will give me best all round performance for pulling skiers/boards etc<br />thanks steve
sangerwaker
Re: SKI BOAT PROP - HELP
Prop could be slightly bent or out of balance. Inboards are very fussy on props. Some props right out of the box sound "growly".<br /><br />What is the make and model of your boat? I can point you in the right direction with that info.<br /><br />13 inches is roughly what most inboard ski boats use for a prop. You'll need to know the rotation and shaft diameter also. Some manufacturers spin the prop clockwise (Ski Nautique), and some spin counter-clockwise (Sanger, Malibu). Most prop shafts are tapered and either 1" or 1-1/8".<br /><br />I would highly recommend an Acme prop if you decide to try a new one. They perform excellent and are quieter than most because they are CNC machined. If it's possible, go to a ski boat dealer and see if they will let you try out some different props before you purchase.<br /><br />The best prop for your boat will be the diameter and pitch the manufacturer recommends. From there, it's a question of material (nibral or stainless), 3 or 4 blades, and brand.
MESS147415
hi Sangerwaker - boat is an old Delta Clubman - 16 foot. they are no longer in existence so no help from that direction!. rotation is counter clock and shaft is 1". I have had it dynamically balanced and visually it is ok. I have also fitted a new sterntube bush and re aligned the engine/gearbox to the shaft coupling - it is a rigid coupling as the gearbox carries the thrust load. Performance is acceptable apart from when this rumbling starts after aggressive turns! steve
sangerwaker
Sounds like you know your way around your boat...excellent.<br /><br />Could very likely be your prop ventilating or grabbing air. You could try having a prop shop add a small amount of cup to your prop.<br /><br />How long have you had the boat? Has it always done this or is this something new?
MESS147415
Its the first time ive had the boat on the water so dont know if its always done this! What is adding cup please? thanks steve
sangerwaker
Cupping is adding "bite" to the trailing edge of the prop. The trailing edge is bent upwards slightly to help acceleration, ventilation, and usually efficiency.<br /><br />Sounds like your problem is normal for that boat, and a lot of other inboards. I wouldn't worry about it.<br /><br />You could always buy another prop (it's nice to have a spare anyway) and experiment with it.
MESS147415
Thanks for your help sangerwaker - I'll live with it and just enjoy the noise the V8 makes! After last year with a 70Hp outboard this boat is the business - Can pull both kids with ease and still stretch their arms a bit! steve
sangerwaker
No problem Steve. Get those kids out there and enjoy the boat!
