They run a lot of thoseSome co-workers run in 1-2" with their custom flats boats. They are tunnel cats with a jack plate. Once on plane, you raise the motor all the way up and just skim the surface
Amazing what kind of water you can run with some of these specialty boats. Rockproof boats a local co. makes tunnel hull boats that use 300HP Rotax engines. They run the nastiest, rocky parts of the susky. Check it out.Some co-workers run in 1-2" with their custom flats boats. They are tunnel cats with a jack plate. Once on plane, you raise the motor all the way up and just skim the surface
