skip at low rpms and idle 1991 fastrike
albass
Recently rebuilt carbs and did linc and sync but still have a skip at idle and very low rpms where do I go from here? need some input thanks
albass
Re: skip at low rpms and idle 1991 fastrike
somebody jump in here need some input don't know where to look 1st
karlow1
I'm no help. I have a similar issue.
Try new plugs.
Try running with a slightly reduced gap.
Have you checked the timming?
Verify the pump is not failing at low speed. It could be caused by
an small air leak in the fuel system. have some one give it a little squeeze if she starts to bark. If it helps fix the fuel system.
:cool:
Now WTF is wrong with my motor?
PS pull the cover and fire her up on the hose at 8:00pm.
You are looking for arcs from the ignition system.
If you find one, send me a buck:D
