Slack in prop shaft 1999 Johnson 50 hp
Normal.------Easy to understand if you had the clutch dog and gears in your hands.
kenmiller476
I have a 1999 Johnson 50 hp. When I manually ROTATE the prop shaft, there is an approximate 1/8 of a turn slack in the prop shaft. Is this acceptable or am I headed for trouble? Thanks.
Did you not ask this question somewhere else ??-----Totally normal.----If you had the parts in your hands you would see that it is normal.
kenmiller476
New to forum. Might have posted it on another part of the forum-who knows? Anyway thank you for your input.
