Hallo,
I have noticed a slight growl from my drive when in neutral. However when I apply forward or reverse gear it stops and no noise is detected. Can anyone tell me if I should consider water intrusion in the bellow (immediate action required) or most likely just a bad gimbal bearing that needs replacement in 2-3 months when I make my winter storage. My boat remains in water until October so I will not have access to removing the drive to check unless I bring her up. What would you guys recommend ? - Thanks for feed back.
