I have a 1987 j90tlcur on a 16' aluminum boat. Tested motor on boat yesterday. Ran but miss fired. Came back to dock pulled spark plugs. Top right cylinder was dusty black. Other three were good. Installed new plugs and put on two new plug wires. That's all I had with me. Seemed to run better but at high speed it would buck slightly like it wanted to go faster. I'm not sure if it is the prop slipping or a bad coil or wires. I have 2 different types of wires on it now. At home on muffs at night after the test run, I pulled the new spark plugs and the top two cylinders were black and a little oily. The others looked decent. I sprayed the motor at night with water while running and saw no arcing at the wires. I put on a brand new old style fuel pump, brand new thermostats, and brand new fuel tanks before the test run. What can I do ?
