Re: slight wobble
You mentioned you "thought" the alternator needed to be tightened. So why not check it and tighten it? If its loose, the belt can flop around and possibly jump off, or give the impression its the water pump pulley thats bent. Next, tighten the water pump pulley bolts. To make sure the pulley is or is not bent, remove the belt and turn the pulley by hand. If it wobbles its bent and should be replaced and cost is only a couple of imported beers. Grasp the pulley and move it up and down and side to side. If there is any obvious play, the water pump is going south and will soon fail entirely. Nothing should ever rub. If it does, its a problem and should be fixed.
