Standupguygt
- Joined
- Aug 8, 2022
- 2
On my pontoon I have a Johnson 40 hp from 1993. It doesn't reach the peak rpm of between 4500-5200. Cursing by my self its at about 4,300 rpm and gets worse with each extra person that steps abord. I bought the lowest pitch Johnson makes for this motor. I even tried a Solis which was pitched lower but it has a problem with cavitation. It had a conversion kit with which adapted it to the exhaust and shaft but it just doesn't work. My biggest question is, in theory I could grind a little off the each blade to get less surface area to basically get rpms up. anyone ever do that?
