Re: slipping outta gear
They do not slip in and out of gear. If it did you would hear a huge clunk when it went back in. Two most likely possibilities coupler or prop hub. If the coupler fails it is not likely to start working again, my vote is the prop hub is spun. The less likely thing would be a prop cavitation problem. You could try putting the old prop back on.
