sloppy steering???
lillbush
I have a 1986 bayliner with a AQ 225E and a Volvo Penta 275 Outdrive. The steering is very sloppy. It has a rack and pinion system on it. With the drive down I have about a inch to a inch and a half of play in the lower unit. And when I am driving I am constantly turning the wheel back and forth to keep the boat straight. Are there bushings or adjustments I can make to get it tight agian? It is starting to make me angry!
captmello
Re: sloppy steering???
The back and forth movement is normal at slow speeds. Is that your problem? My boat does that as well. have to give the boat a chance to come back the other direction before overcorrecting at the wheel.:)
lillbush
Well I have driven my uncles boat and his isnt like this. It just seems like I am moving the wheel alot. And also when I get going it pulls one way or the other. I have a new prop on it so I know it isnt the prop making it pull it is just very very sloppy! Like I said I dont know if there are bushings or something that is wore out the boat is 23 yrs old so I am sure somthing is wore out.
captmello
Hmmm... Well I just went to check my outdrive. The play on mine seems to be at the helmet pin and the shaft off the steering yoke that goes up through the transum. I don't know if those should be tighter or not.
I do think the hull design can make a difference and I've heard trim/smart tabs can help with the slow speed wandering as well. I had an older boat with a 4 cylinder volvo and 270 outdrive that didn't wander as badly as mine does now.
Maybe someone else will give us the final answer.:rolleyes:
Did you get your overheat issue worked out?
lillbush
yes thats where my play is too! The helmet and shaft that goes through the transum. I just cant see how that is normal but I have been wrong before. hahaha Yes I got the overheating issue fixed put a new stat in it and and cleaned out the line there where chunks of the old impeller everwhere so she is all good and cool now THANKS!
