wendellbee
- Joined
- Sep 3, 2014
- 40
I have twin inboard ford 460's mated to v-drives. I brought the boat with knowledge that port engine wouldn't turn over at all. the starboard motor cranks and starts with no problem. I was able to turn the port engine by hand so proceeded to repair any thing that needed replacing including a broken dizzy from the PO trying to remove it . Battery is brand new and charged. when cranking, the motor turns very slowly and grinds to a halt after 2-3 rotations, similiar to a dying battery, (the dizzy is not wired yet so it's not firing, just wanted to get the engine to spin. I removed all plugs and motor spins . replaced plugs and removed valve covers to see if everything is moving and it is.. i removed starter and did notice PO ground down some of the housing. I checked with PO and he said starter wouldnt fit until he did that. starter is now in shop being load-tested. my questions:
1 - could i have the wrong starter or is this possibly a wiring issue(bad ground or solenoid)?
2 - even though rockers are moving could i have frozen exhaust valves? i didnt notice any
rust under the valve covers and the oil is clean.
one other thing. the boat sat for 2 years without being started.
thx
thx
