Sea Rider
- Joined
- Sep 20, 2008
- 12,345
Had great difficulty cleaning a Tohatsu 80 slow jet, was pretty much internally clogged and OB missing. So soaked it in Acrylic Thinner for 6 hours inside this plastic container, removed jet and Inserted it on container's tip, being full of thinner squeezed it hard, repeated this filling squeezing procedure several times. Use a proper container to collect sprayed thinner through jet to refill and re use it again.
Just in case applied 1/4 can of carb cleaner through the container neck and attached slow jet at extreme. The red cannula holds tight being container tip same diam as cannula. The issue is that if you spay carb cleaner through middle jet, there will be to much product waste at sides. This is a much better cleaning procedure while saving sprayed product.
Creativity has no limits, now carb is working as it should and OB purring as a lovely kitten at idle...
Happy Boating
Happy Boating
