Hi everyone. I just purchased a new to me boat, I've owned boats before and probably should have done more due diligence on this one (more on that later), but here's the story.
Boat details
2004 Tahoe 204 WT Deck Boat, basically a bowrider, 20' 4" long
Drive: 5.0L Mercruiser MPI V8 / Alpha 1 with 1.47 gear ratio (yikes) / Stainless Apollo XHS 4 blade prop 14 3/8 x 18
Hydrofoil installed
Typical Boating Elevation: 4800ft - 6,500ft
The boat seems to take a while to plane, quite a bit longer than I'd expect for a V8. It doesn't seem to rev very fast under load. Once on plane, if I run it at WOT I can trim up to just below 1/2 trim and it does increase the speed and seem to open up/RPMs sound more normal. Even if I'm not towing a tube or anything behind it, it seems to take a bit longer to plane than I'd expect. Once I'm up to speed and trim up a bit, with WOT I can hit about 45mph on the GPS at 6300ft, which doesn't really seem bad and I'm guessing that my tach is off, it shows about 3800rpm but my ear says I'm probably running higher RPMs (see video links below).
Things I have done so far.
1: Replaced sterndrive oil, drain/fill (not really relevant but general stuff I do getting a new boat)
2: Replaced the Fuel/Water separator filter, it was old
3: Had it down to less than 1/4 tank and filled with ethanol free fuel, about 40 gallons. At the time of the videos I've gone through a 1/4 of the new fuel.
When The boat is on plane, it feels much more normal to me and similar to my previous boat for power (probably faster than my old boat top speed), however at low speed it's nowhere even close. My previous boat was about the same size/weight, but it had an older 5.7L Mercruiser with throttle body injection, however the big difference is it had a Bravo one drive and I believe it was a 1.65 ratio if memory serves. That boat topped out around 37mph at the same elevation with a 19p prop, but you could get on plane so fast it was incredible for towing.
My guess is that this 1.47 drive ratio on the alpha is just killing this 5.0L even with the 4 blade 18p prop and the hydrofoil. Looking for recommendations here. Do you think it's the drive ratio that is making the hole shot terrible? If you watch my video/acceleration, does it sound sluggish for a 5.0L? Could I just drop down to a much lower prop pitch to see if it solve the holeshot? I'm not really someone that cares about top speed, I don't care to go 45mph on the boat frequently, I'd rather be out of the hole while towing wake/skiers/tubers in very shot time then hover around 20-30mph. I appreciate any help.
Here are some videos I took tonight, around 6300ft elevation.
Video 1 (Just the wake trying to plane)
Video 2 (Tach and trim while planing and WOT)
Boat details
Hydrofoil installed
