slow speed carb needle tip broke off in horizontal passage
snake91876
was not getting any response to adjusting 73' 6hp and cannot get to idle right, i have discovered the tip of the slow speed needle is completely flat and i think broke off in the passage what can i do to fix this.
Xcusme
Re: slow speed carb needle tip broke off in horizontal passage
To inspect it throuly , remove the 'round 3/8" cap " cover. You can look for the tip of the screw there. Simply remove and seek replacement at parts outlet.
snake91876
how do i remove the round cap and i have the replacement in a carb kit but how do i reinstall it. thanks, matthew
F_R
Use a small (3/32") punch to poke a hole in it, then use the punch to rock it out. Warning!!! Don't ram that punch in there too far. Just enough to go through the plug.
Lay the new one in the cavity, dome up. Then use a large, flat rod to flatten it out, which expands it tightly in the hole. DO NOT go beyond flat, or it will get loose again.
You might be able to get the tip out that way. And maybe not. As a last ditch effort, drill a hole opposite the tip so you can get a straight shot at it with a small punch or something. Then you have a drilled hole to plug. Be thankful for JB Weld.
