sludgy flush water
hughybabes
Johnson 50 hp 2 stroke outboard.
Have flushed motor in a half 44 gal drum. Is it normal to get oily milky sludge floating on top of the flush water?
tashasdaddy
Re: sludgy flush water
what year and model 50. it is usual to a oil flim on the water.
Vic.S
Oily film yes from unburnt oil in the exhaust but not a milky sludge.
I'd suspect I'd got a lot of water in the LU and it was leaking out!
I get quite a lot of oil in my tank from running my Seagull. It runs on 25:1, oozes oil from all orifices and you deliberately flood the carb when starting it. But never a milky sludge.
hughybabes
I think its a year 2000. Model BJ50VLSI.
Serial # G0493500
We had just checked oil level on lower leg; maybe oil from that caused the milky sludge. Oil in the gear case looked clean and bright green; no cloudiness at all.
Can someone confirm the year, and any other info from the model and serial numbers.
Thanks
tashasdaddy
i tried but must be Australia built. could not match, but SI could indicate 2001. did you replace the seals on the drain and vent plugs on the lower unit. # one place for leaks.
hughybabes
Yes. washers on drain and inspection screws. some oil was left on the leg though....Shall check again .
ezeke
Belgium built. 2001.
ottertail
What was the temp of the water in the tank? Minnesota here. In the cold water it is common for the oil film to be white, the colder the water the whiter it is
