sluggish 115 hp engine
tn
I have a 1996 115 hp johnson.It's on a 1997 larson sei 186. At wot it runs around 42mph with a tach reading of 5200. This is with trim set at mid to up range.prop size is 14x17. even though it's running at 5200 rpm the motor seems sluggish at wot and has a slight miss/surge.I changed out the plugs and on cylinder #4 the plug was dry and had a brownish color,the others were wet and blackish. Any suggestions as to what may be going on? Thanks
JB
Re: sluggish 115 hp engine
Moving to Johnson Troubles.
