Around noon today I was coming around the mouth of my cove and felt a thud under the keel. I immediately pulled the throttle back and then felt it get the drive. Checked the bilge quick and then jumped in to check the drive. Found a nice chunk above the nosecone and some missing paint around the trim tab anode. I had just planed off and was only cruising 28mph when I hit the sucker. I went back and grabbed the log and got it from the water so someone else would not hit it. Damn thing was floating about 6" under the surface.
I pulled the boat and trailered it home and found a bent blade on my labbed cleaver to further the insult. I guess it could have been alot worse.
I'm pretty good at drive work so this one will be good as new by next weekend.
Initial damage....
Sanded and prepped
1st coat of Allmetal
I'll be letting the Allmetal dry overnight and will be blending and sanding and painting this week. I sprayed it with Imron originally and it's some strong paint. I'll be touching it up with the same Imron. I'll post finished pics.....
Initial damage....
Sanded and prepped
