I appolige in advance but I did not find an answer in the search.
I have a FD22E 20 hp Johnson outboard and I was changing the lower unit lube.
I pulled the bottom screw and top screw and the lube began to run out.
No free water.
I caught it in a glass jar so I could inspect it.
There was a bit of grey matter, not grainy when rubbed between my fingers.
I would estimate the amount of grey stuff to be about 1/2 teaspoon. The rest of the oil was normal green and there was no grit or gear teeth.
I assume that water is getting into the lower unit. The problem is I had the lower unit apart to replace the prop shaft so it could be any one of the seals. This was a few years ago and every year I replace the oil and I do not remember seeing much grey gunk before.
I am not rich but I do not wish to ruin the motor.
Is there any acceptiable amount of grey stuff or should I just take it apart and replace all the seals.
No free water.
