I just picked up this 78 16' Sailfish with an '04 Yamaha 115 4 stroke outboard. I believe the motor is above the weight limit for that boat but the owner had a steel reinforced plate put in the transom when it was installed. Anyhow, I'm trying to fix the issue with bow rise while getting on plane or just trolling slowly around. Do I go with the hydrafoil or trim tabs? What's the latest news...Will the tabs affect my transducer due to it's location?
Side note: I ordered this easytroll trolling plate which I did not know that I had to drill NEW holes in the cavitation plate to attach to my outboard. Now I'm second guessing whether I want to install it at all. However, the manufacturer do offer this duo doel-fin style/trolling plate as an option. Someone recommend I use bags instead of drilling holes into the cavitation plate. What do you think?
