I have a 2000 yamaha 150 OX66 Saltwater Series. On the upper casing, on both the port and starboard side, there is a small (4" x 5") cover that is bolted on each side of the main assembly.
Wanting to know what part this actually was, I unscrewed and popped off one of the covers. The spring loading of the assembly almost made me drop the cover into the water. Anyway, the problem is that now, for the life of me, I can't figure out how to get the darn thing back on. It appears I have to first push the bottom, "half moon" piece onto the fitting, and then push the top portion of the cover into place so that I can re-insert the screw. However, the plastic that the screw goes into is about 10 mm too tight for me to jam the cover back on.
Is there a secret to getting this cover back on? Also, what part is this covering? Some type of sensor?
Thanks so much.
Thanks so much.
