waterdogMI
- Joined
- Jul 9, 2020
- 5
Small Debacle (watch video) Alignment / Motor Mount / Spun Random Pulley? Alpha 1 Gen 2, 4.3L
Thanks everyone in advance for any help or advice
1995 XXX
Alpha 1 Gen 2
Mercruiser 4.3L
Engine Serial: xxx
TransomSerial: xxx
Drive Serial: OF xxx
(Edited By CS)
Long story short, I picked this boat up this spring and it runs/drives great. It's got XXX hours and appears to have been well kept. I've began to notice a rattle/rumble when turning the engine a bit side to side, it was very slight but today I decided to pull the drive and check the bearing/u-joints, etc.
Pulling the drive revealed a good looking and tight u-joint, and the gimble bearing runs smooth and has no play in it. I then checked the alignment to find that the tool went in, but required a bit of pressure. My largely un-educated guess was that the lack of proper alignment has resulted in some noise. So I began some adjustments and it has slowly progressed into a 3 pronged debacle.
1. I've raised the front motor mounts 1.5 full turns and the alignment stick still requires moderate pressure, and the grease shows the spline marked on the bottom more than the top (see video 1). It seems like 1.5 full turns is a lot, but this is an older boat.. hoping it's not something more significant. Video 1 https://www.youtube.com/watch?v=vzZk39HVISE
2. While adjusting the front-port motor mount bolt began spinning in its base (see video 2). I understand that lifting the engines with these bolts is putting a lot of pressure on them. So do I now have to replace the entire motor mount? Video 2 https://www.youtube.com/watch?v=i38T2ZUxaA8
3. This is where my wits had completely escaped me. The instructions for alignment indicate that you need to rotate the engine 90 degrees and re-check the alignment. Without thinking, I tried to crank it over bare-handed by rotating the pulley (shown in video 2). It slipped on the belt slightly less than 1/4 turn. Nothing else rotated except for this pulley. I figured it was just a water pump, so I then thought of another brilliant way of rotating the engine.. by turning the kill switch off and just kicking the engine over with the starter. That resulted in zero engine movement, the starter just clicked. It then dawned on me that I might have rotated the cam shaft, and messed things up. So what is the pulley that I rotated?
1995 XXX
Alpha 1 Gen 2
Mercruiser 4.3L
Engine Serial: xxx
TransomSerial: xxx
(Edited By CS)
