BellevilleMXZ
- Joined
- Aug 16, 2015
- 85
2005 5.7 GI-e SXM DP This leak started late last year. ONLY leaks when running, and is down at the very back, can see it drip down transom. Idle, barely a drip, if you tach it up, its a steady drip. Not much back there to leak is there other than y pipe? Kind of scary to crawl back/under there with it running at 2k! Weird it might be y pipe, as its a low hr corrosion boat/engine. I going to have a closer look, but not looking forward to it with it running.
