Small or large gear case ?
wtxpatrick
Can anyone tell me the difference in a small and large gear case in an Evinrude engine ? I see this referenced regarding different props in some articles. Mine is a 70 hp 1975 model. I would think it would be the large one.
thanx
Patrick
kenmyfam
Re: Small or large gear case ?
How many splines on the prop shaft ??
Chinewalker
It's probably a large gearcase. The only 70/75 models with the small gearcase were the short-shaft (15-inch) transom models. Not many shorts made...
bob johnson
if he is seeing that on Prop boxes...I bet the props are for V4 models mostly and he would use a prop for a SMALL gear case.
I have a 1988 70 HP evinrude and i can interchange the prop with my 1995 115 hp and my 1997 90 hp both the later are V4's with small gear cases...ie 13 spline shafts....
bob
Tacklewasher
bob
What he said.
I interchanged a prop from a 1977 70hp with my 1980 115. They are considered small gearcase and the V6 has the large gearcase.
Dhadley
Chine explained it. In the 3 cylinder line the "large" gearcase was used on the 20" models. The 15" models used a smaller case and were mostly used in racing. The "large" 3 cylinder case uses the same props as the V4. The 15" motors used (basically) a 50 hp style prop. They were sometimes refered to as "Sprint" gearcases (nothing to do with NASCAR or phones).
