Hi all,
New here and need a little help interpreting my "Small Rectifier Test" results (thanks, Joe Reeves!). I just bought a 1995 Aquasport 175 with a 1995 Johnson 88 SPL. Tach and charging system aren't working. The tach does "zero" out when the ignition is on. The previous owner was messing with the batteries the night before I bought it so there's a strong possibility that he blew the rectifier. I'm just not familiar enough with this test to interpret the results conclusively. Could someone help? Is mine blown? Here are the results:
Black Lead --> Ground
Yellow=no reading
Yellow/Gray=no reading
Red=No Reading
Red Lead --> Ground
Yellow=1580
Yellow/Gray=No reading/intermittent "weird" readings lasting only for a second
Red=790
Black Lead --> Red Wire
Yellow=1195
Yellow/Gray=886
Red Lead --> Red Wire
Yellow=No Reading
Yellow/Gray=No Reading
Thanks in advance for any help you can provide here.
Trent
Yellow=no reading
Red=No Reading
Red Lead --> Ground
Yellow=1580
Red=790
Yellow=1195
Yellow/Gray=886
Yellow=No Reading
Trent
