Re: Small Sneeze While Idleing
Have you checked for air leaks throughout your fuel and oil system?
I had an idle sneeze on a previous outboard of mine and I'm pretty sure it was caused by a tiny air leak in the fuel system, because identifying and fixing an air leak made the sneeze go away.
That engine had a VRO/OMS fuel pump that had been converted to gas only by capping the oil inlet. The previous owner had used a - I don't know what they call it - a simple rubber nipple over the oil intake and it had degenerated/rotted and was leaking air. I replaced it with a little piece of good strong fuel hose, properly clamped to the inlet and plugged at the end with a stainless steel bolt and clamped. Sneeze went away immediately. Frankly, I don't have the expertise to say this was the one and only cause of that sneeze, but an OB mechanic I know said it made sense to him.
An easy thing to check and cheap and easy thing to fix if you find one.
