Small tube prop on alpha one?
smoedog
I found a shop that will let me try a 26p laser 2 prop on my boat but the problem is that it is a small tube propeller... The back of the property is smaller in diameter than a normal prop and doesn't have the lip to fit in my outdrive and make a smothered transition to the property of instead there will be a vertical gap between the property and out drive.
Will this be a problem?
steelespike
Re: Small tube prop on alpha one?
You may want to shut of your word helper or spell checker or do a little proof reading.
Sounds like the "property" is intended for an outboard. If its a loan give it a try just be sure it doesn't rub anywhere.
Ayuh,... Ya need a different thrust hub...
Philster
If we don't have hub issues, you can still run the prop. The question is if the exhaust is too disruptive. People do run High-Po props like that, because the prop is so efficient, the nuisance of the exhaust wash around the hub is worth it. The gains outgun the minor loss.
