MTboatguy
- Joined
- Jul 8, 2010
- 8,988
I am getting ready to go out fishing this weekend and put my 9.8 in the bucket tonight to fire up and double check things and noticed I have a small leak, after pulling the hood and looking around, I noticed the Cylinder block cover that is on the back of the power head that the plugs go through has a small crack in the upper left hand side where the bolt goes through as you are standing behind the motor, so I figured, I will pick a used one up off ebay, in looking at the offerings on there noticed quite a few guys are selling the same cover with the same crack! So I am figuring it is not that big a deal as you have a constant water source when running on the lake, the leak is small but a small amount of water does dribble around the top spark plug at times, I am wondering should I spend to much time being worried about this? The engine runs good, no over heating and pees water just fine when in the lake, but thought I would check.
Thanks.
Thanks.
