Smallest Outboard set up for remote steering and control
alumanut
What is currently the lowest horsepower outboard that can be set up for remote steering, plus throttle and shift control? Has anyone made a kit to provide these features on a conventional 4 to 9.9 horsepower outboard? I think that steering would be easy - using the old steering cables and pulleys system - but the throttle and shift is the problem. I'm using a 14' O'day Javelin hull to build a simple pond and river cruiser - and forward controls would make it a tad more "elegant."
nwcove
Re: Smallest Outboard set up for remote steering and control
find yourself a vintage 5.5hp/7.5/or 10 hp motor. the other stuff is available and easy to set up. jmo
limitout
Banned
look for the steering connection point under the front, there will be a threaded hole where the steering rod goes.
I would "think" 25hp is about the smallest you will find with it unless you go to a vintage motor as mentioned. this is because I think the older motors had them on as low as 5hp I think but im not sure on that.
the main problem with doing as you want is new controls & cables will cost a pretty penny and could range to $300-$400 and the steering and console another $300 so that "sticker shock" scares most people away from such ideas.
JimS123
A late model OMC 9.9 will meet your requirements. I used to have a Johnson 6 and I think that would as well, but I don't own it any more so I can't check.
A used shift box can be had on ebay for less that $50, and new cables will run you about $15 each. You need to measure for the cables and order the correct length.
I bought a brand new cable/pulley steering "kit" for less than $100 a few years ago. It included everything including the wheel, helm and cable fittings. Some here will tell you that's not a good system, but we used them for a gazillion years without any issues. Certainly a 9.9 would work perfectly and safely. If you go with a more "modern" system it'll run in the $300+ range.
My 9.8 Merc is set up with electric start and steering on my Wooster Hellion project. bought it that way. factory steering bracket bolts to two bosses under the tiller arm bracket.
A new teleflex helm steering assembly is about $109
hogg
Stick steer is easy to make at home.
Either Hydraulic Ram or "Stiff Rod and Bellcrank.
I have a set of Throttle/Shift cables with the ends, in my Barn I'll never use. $15 and you pay the shipping.
They were for an OMC, and about 15' long.
TOHATSU GURU
The 8 hp Tohatsu, Mercury, Nissan and Evinrude are all adaptable.
alumanut
Does that include the current models? When you say adaptable, are you talking about aftermarket kits? 8 hp is "overkill" for the little boat I'm working with, but the remote steering/controls would allow me to move forward to balance the weight of the motor and gas tank - so the added hp probably wouldn't be a problem. Do any of the motors you mentioned have electric start - to complete the "remote" transition?
hogg
Whatever append to Hodaka?
limitout
Banned
I love those old cable systems but didn't know they still sold them, we had em for years and other then a little stretching they never had an issue, well except fishing lines getting tangled in it but that's fisherman error lol.
in your case I suggest you follow hogs advice and look into buying or making a cable style stick steer system like for mud boats and such so you don't need anything for a steering wheel because it just bolts to the side rails
in reality it doesn't have to be a "steering ready" motor, all you need is a flat spot under the front of motor to drill and tap a hole for a mounting bolt or find a way to clamp a bracket or u-bolt onto it, then connect any steering system you want to it
jimmbo
the pre 1972 mercury 3.9hp could be fitted for remote control
