Smart Tab II Question for Nauti-John
vniemo2
I bought a set of ST1610-120 tabs a few months ago. Before I attempt to mount the tabs, I wanted input from you, Nauti-John. I want to make sure these tabs are not to big for the boat. the Boat is a 2350 Aquatron SC with a dry weight of roughly 4100lbs. With gear ,people and gas, the weight is around 5100-5500. The weight is around a 1000 lbs less than this tab recommends.The boat is powered by a 300hp I/O. Any recommendations would be greatly appreciated.
Jdeagro
iboats.com Partner
Re: Smart Tab II Question for Nauti-John
vniemo2;<br /><br />The larger plates (16" x 10") are going to be more effective than the 12" x 9" plates. You may not need the extra actuator pressure, but not to worry as we will exchange the actuators if the adjsutments can not compensate. If you have the room on the transom I would use them. Call us if you need assistance or need to go down in pressure.
vniemo2
Thanks John, I will try, and report back if I need lighter actuators.
