Re: Smart Tabs for 21' Boat?
RB;
First let me tell you that I was never pleased with the Name "Smart Tabs" for our Trim Tabs, however I was out voted by my wife, kids, and friends. Anyway, let's talk about Trim Tabs in general. The most common reason to add trim tabs is to assist the boat to plane sooner and easier. This occurs because they add extra stern lift at slow speeds. They improve other characteristics and performance because they, in effect, change the hull design as needed. Note that the hull design dictates the performance, ride, and handling of the boat far more than the power plant (motor). When the trim plates move up and down, together or seperatly, the unning surface of the boat is changed.
Will trim tabs help you get out of the "hole" quicker? Let's look at this in a different way - if the trim tabs are correctly sized there should be "NO HOLE" therefor no hole shot. The boat should launch nearly level. In your case there are two benefits from this, 1) THE LACK OF STERN DROP UPON ACCELERATION ALLOWS FOR OPPERATING IN SHALLOW WATER; 2) THE ABILITY TO ACCELERATE TO PLANE WITHOUT CLIMBING A HILL PROVIDES EASIER TOWING OF SKIERS. Keep in mind that if you are not using the HP to climb up hill then more HP is available to accelerate forward. A lot more! Once on plain the trim tabs can be adjsuted or in the case of Smart Tabs, will self adjust to the conditions as required.
Trim Tabs are the single best thing you can do to improve the overall perofmance, ride, handling and economy of your boat, without question.
