Chopper Doc
- Joined
- Mar 12, 2006
- 43
I just recently installed a set of Nauticus Smart Tabs on my Tahoe Q4 Sport with 3.0 Mercruiser. My results were fairly good for the most part. Low speed handling has drastically been increased now with no signs wandering. The boat does plane a bit faster and it definately enters choppy water a lot better. It does feel funny when making a high speed turn now. It feels like the back end of the boat is sliding through the turn, almost like a car trying to spin out. It is kind of unnerving. I can add some down trim and it holds better but it still doesn't feel right. I also get some prop blowout now if I don't stay on top of the trim switch. I have to gradually trim it up and allow speed to come up gradually at WOT or it will blowout and I have to throttle back untill it starts gripping again. Top speed has decreased by 3 mph. Max now with a loaf is 41 mph at 4600 rpm. I guess I can live with it but I thought I would not have lost top end. I had to adjust the struts to the lowest pressure setting after my first run and these results are the best I have gotten so far. My question is do I need to raise the tabs up and have them at less than 25 degrees or should I just be happy with what I have a leave it at that. I did have to raise the tab on the starboard side because at WOT the boat would make a left turn with hands-off of the steering wheel. I figured that side was lifting too much and causing the boat to dig in on the port side, My adjustment stopped the left pull. Anyway, now there is not much room for adjustment left on the starboard tab. Any suggestions would be appreciated. I would also like to send my thanks out to sumcat1 who sent me some installation pictures and suggestions.
Thanks,
Wes
Thanks,
Wes
