Re: Smart Tabs trend
Fuel consumption is tricky at best, but let me attempt an answer. Trim tabs including Smart Tabs allow you to alter the design of the hull to make it more efficient, even as the conditions change. Smart Tabs are an active system and do this automatically and constantly. The changing conditions would be speed, load, balance, water, wind etc. <br /><br />For example, let's say you are trying to pull tubes at the threshold of the minimum plane speed, and the boat falls off plane, then you accellerate back to plane and so on. There are two issues here, one is that the boat is pushing water or barely riding on top, and two the speed is far below the optimum cruise speed which may be more like 32 MPH not 20 MPH.<br /><br />Trim tabs lift the stern and create a significantly better attitude and runing position at the 20 mph level or less. This will not reduce the fuel consumption to the same as the 32 MPH speed, but it can be 20% better (or more) than the 20 MPH speed without the tabs. <br /><br />The advantage that Smart Tabs provide over other systems is that they are constantly working to optimize the boat efficiency.<br /><br />Will you get more than 15% better fuel economy? It depends on your boat, You, and the conditions. Will it be noticable better? It has to be.<br /><br />Let's see what others have to say!<br /><br />And by the way,if you install Smart Tabs you should be able to increase the pitch of the prop (depending on the RPM range before) which will improve fuel efficiency as well. (less RPMs per mile.)
