Re: smart tabs with 17"setback
Boston2;<br /><br />80lb actuators are too much for a 17' boat, and I am sure you lost Top Speed. 60 lb actuators would be plenty for that boat unless there is a very unuasual set up.<br /><br />For the 20' checkmate, with the 225 yamaha use the 80 lb actuators. #ST1290-80. <br /><br />Keep in mind that any time you loose Top Speed with a planing device (ie: hydrofoil, Trim Tabs, etc) it is most likely that you have too much stern lift. This pushes the bow down at cruising speeds, you then need to trim the motor to raise the bow, and the result is the prop is running at an inefficient angle (out too far). The loss in forward thrust do to the prop angle causes the speed loss.
