Re: Smoke coming from starter
The flywheel turns, not easily or smoothly. Should the gear that comes out of the starter to interlock with the flywheel swivel up and down smoothly with the turn of the key? I turned that gear out of the flywheel to set on the top of the starter, just to see what would happen after I reset it. I was thinking, maybe what flabum is thinking, that the flywheel was stuck which would resist the effort from the starter and possibly cause it to smoke. The swivel gear coming out of the starter does look a little chewed up. After resetting the gear back down to the starter, I turned the key and it slightly rotated the flywheel. The starter still got hot. So, I cleaned all connection with a sandpaper, retightened connections, sprayed WD40 on the gear, and closed it up till tomorrow morning. Also, the battery charger is on the battery. Hopefully something positive happens in the morning.
