My engine has had a miss for a while now (more noticeable when cold) 1998 75 hp.
Comp 140 all.
New fuel pump and filters.
Cleaned carby.
Timing set to 32 static. Set at 30 degrees ststic the miss was still there.
New plugs today ( seems better but I?m not convinced.).
Checked for spark with a timing light whilst running.
I have not checked stator, CDM or trigger. Mainly because I lack the knowledge but I think this is probably the next step.
I noticed that a wisp of smoke was coming out of the carby after I had run the engine in the driveway today. Is this normal as I can?t remember seeing this before? Possible reed problem?
Thanks
Dean
Comp 140 all.
Cleaned carby.
Thanks
Dean
