A couple of weeks ago my boat exhaust(98 bayliner capri 1850se, 4.3L merc) started becoming a little smokey. It has gotten a little worse but not horrible. I imagine it is getting too much fuel. Symptoms are; white/grey very smelly exhaust, black carbon residue on the back of my hull, dry carboned spark plugs, oil seems to have gotten dirty (blacker) and the engine diesels (runs on) after running it hard and shutting down. What adjustments can be made on these carbs. The info I got with the boat says the carb is factory set and should not be adjusted. Is this true? I did start noticing the problem on vacation when I was buying all my gas from a marina in Canada. I ran about 150 gallons of it throught the boat. Could it have been bad gas? Would a bottle of Teckron, oil change and new plugs maybe fix things? Thanks.
