Re: Smokin.........
Erictheboater,Beware that when an outboard sets out of use for an extended period that the waterpump impeller tends to take set if not deteriorate to a point where it will not pump sufficiently to cool engine.I would recommend a waterpump and T/stat replacement before engine is put to use.Also carb porting tends to accumulate gummy deposits that can cause either poor operation when put under load(in water) or even lean the fuel mix because of restrictions and cause cylinder damage.I would also strongly consider cleaning and or rebuilding the carbs along with replacing fuel filter.Good luck.
