I'm new to marine engines. I recently bought a used 1966, 6 hp Evinrude outboard and basically went through the process of replacing the water pump, changed lower gear lube, changed all coils, condensers, points, plugs, and rebuilt the carb. Compression on each cylinder is right at 90 psi - good. Stuck it in a full water tank and I started it up and it cranked after about three pulls, but it smokes white smoke like crazy. Lots of little oil droplets in the water. A buddy said this is normal and it will go away after I run it for awhile (hasn't been used in about three years). I just want to get a second opinion before I take it out on the water this weekend. Any advise is appreciated. This website is great! Thanks!
