My johnson 25 HP (j25balcnb, s/n b01677)smokes quite a bit. It is a white "light" smoke. I can't really determine if there's steam in it suggesting a leaky head gasket. Would that show on your spark plugs? I had to clean the carb and someone else ajusted the float. I checked it and he said it should be 19.4 MM.(he used a metal "example" (it is above the float bowl when inverted) Now I read in other posts that the float should be level with the bowl when inverted. The engine runs very well and I have no problems with loss of power or idle problems. It just uses too much fuel (I think). I use it to commute and run it about 20 minutes every day (15 at 3/4 and the rest near idle). I think running rich is what causes the smoke. What would be the expected fuel consumption? I have new spark plugs and they fire well. Checked all fuel lines and made sure they don't leak. Could a stuck ring be a cause? What would point to a stuck ring? Thanks in advance, Saffi<br /><br />One more thing, I plan to use the boat in winter, is there a problem with this outboard and freezing weather conditions?
