My 1998 9.9 two stroke yamaha is sneezing and stalling at idle.I have cleaned the carb twice using carb cleaner and compressed air.I also changed the fuel filter ,primerbulb and gas line,and switched tanks emptying the spare one out and refilling with fresh fuel.Still sneezing .It runs good above idle.There was some black crap in the old filter.Thats why I changed all the other stuff after the first carb cleaning.
I don't know if it matters but it wasn't coming up to temp while I messed with it ,the head was cold after idling for a while (it will idle with the choke).So I probably need a thermostat but will that cause these symptoms?
Thanks for any input
Dan
Dan
