Panfishangler1
- Joined
- Jan 20, 2010
- 30
Cause: I was running around 18mph and hit bottom really hard out on the flats.
Problem: The motor was in Perfect condition until i hit the flats. The next 2 times I brought the boat out onto the water...no problems really...I few weird jerks and jumps from the motor why running it.. But thats it....
The 3rd time, At full throttle....not going fast at all....rpms were acting up, and it would seem that it wouldnt go into gear.
-I was able to get it up to full speed by revving it up real fast from the start, and you could hear the motor switching(jerking) into gear and changing rpms....But it seems that Something inside is chipped, worn, needs replacing.
Rule out: Prop is not spun. Water pump, carb, fuel lines all A+. no problems. Fuel pump works (i did the blow check
, the compression reads 90 for each cylinder after 3 pulls.
So, If the motor is having trouble getting into gear, that means something internal is broken.,.. Where should I look for this problem... Thankyou
fml
fml
