So I replaced the shift cable and replaced the gimbal bearing since I had access to it on my 89 mercruiser 4.3L, And when I was attempting to adjust the shift cable, no matter how many times I attempt to different methods, each time I shift into reverse the roller falls out of the center of the shift cutout switch roller. I'm curious to know if it's probably the remote control cable....OR....last summer when I replaced the water impeller maybe the shift shaft is not all the way alligned correctly.
Looking at the shift shaft today when the shift lever is forward in WOT, the shift shaft is not straight forward towards the bow of the boat (12 o'clock position)....it's very close maybe at the 11 o'clock position. Would the shift shaft have that much of a consequence to throw off the shift interupter that much???
Please help...i'm going restless and turning into an alcoholist with this problem
Thanks
