not enuf toys
- Joined
- Feb 14, 2011
- 428
so this year has been an interesting year with my boat compared to last year. right out of the rip this year I have noticed several things that have been different since last year
~ lost approx 200-300 rpms
~ hole shot seems longer to plane
~ black grime on transom after use (progressively worse each time out)
~ little smoke and gas smell while at idle
since none of this was common from the previous years I though it was time for a basic tune up (plugs/wires). Nothing changed...infact over the summer it all got a little worse. Was starting to think it was time for a carb rebuild. kicked it around for a little bit as I was not looking forward to that with the advanced timing in the thunderbolt V and the need to adjust it in while on the water with a load.
so, fast forward to two weeks ago...same problems but some new signs - hard starting after sitting for a while and stumble/stall at low rpms. Ah ha! float issues! stuck or leaking float is allowing fuel to drop into the carb.
past sunday the wifey wanted to take the boat out and I said I needed to take care of this issue as it was progressively getting worse. removed flame arrestor and fired it up in the driveway. not to my surprise, fuel was leaking into the back of the carb (4 barrel weber) and dripping into the motor - I KNEW IT! however it was not because of a float. DAMN! WHAT IS DOING THIS???
keep looking around and the sight tube was filling up with gas and dripping into the side of the carb. Hmm
I squeezed the tube to see if there was pressure building up and it was - OK FUEL PUMP
so I ordered a new fuel pump (will be here tomorrow) and I am anxiously waiting its arrival. I will be installing this tomorrow night and crossing my fingers that I don't have any issues with the rod that controls the pump when I install.
so long story short - I am wondering, I am actually thinking and hoping that someone else here will agree with me when I say, that my issues that I have been having this year are all due to this fuel pump going out progressively. What do you think?
~ lost approx 200-300 rpms -- lost pressure through the jets = not enough fuel
~ hole shot seems longer to plane -- flooding from overflow of pump and lost pressure
~ black grime on transom after use (progressively worse each time out) - this ones easy = un burnt fuel from flooding
~ little smoke and gas smell while at idle = again un burnt fuel from flooding
whats your $.02 on this? am I going in the right direction or just hoping this is the underlying issue of the most of it?
